Alpine PDX 5 - Questions
My questions are.
1. I know the Alpine can handle both 4ohm and 2 ohm speakers. Can I put a 2ohm sub on the 5th channel and have 4ohm speakers on channel 1-4. Or should all 5 channels have the same impedance.
2. I have four line level outputs from the HU. Do I need to add y-cables to plug into the sub input or does the amp automatically send a mono signal out to channel 5 without anything plugged into the sub input?
2. the amp doesn't automatically sense the 5th channel, you will need to run a set of rca wires to the sub channel. If worst case senario, you run a y splitter on your rear rcas for the sub channel.
I thought that some company makes a LOC for use with 5 channels, but i can't remember who makes it
