Sponsored by: Innova
Dynamat Alternative?
Old Feb 4, 2002 | 02:40 PM
RandallZr1's Avatar
RandallZr1
Default Dynamat Alternative?
Anybody got any good suggestions for a less expensive alternative to Dynamat for sound insulation? Thinking about putting something underneath the carpet during stereo install, but damn that stuff is expensive!
Old Feb 4, 2002 | 09:49 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Dynamat Alternative? (RandallZr1)
Well back in the old days (when money was tighter). Used to get egg crate foam in 1/4-1/2 inch thickness from local packing company. Works great and as long as there is no water leaks will last forever. However in some panel mounting and placement its necessay to compress the ever loving hell out of the stuff.
Old Feb 7, 2002 | 03:24 AM
intel55's Avatar
intel55
Post this on the C5 tech section or offtopic... I saw some guy a few months post a link to some commerical industrial site that sold the exact same stuff that is dynamat for alot cheaper.... it was mucho cheaper and the same stuff... I cannot remeber what it was used for but some industrial damping...
Old Feb 7, 2002 | 01:20 PM
vader1's Avatar
vader1
Randall,
I was able to purchase Dynamat from UBID.com for 1/4 the price of the stereo shops. Check it out. You may have to buy a little now and a little later.
Currently there is this auction on UBID: http://www.ubid.com/actn/opn/getpage...onId=523532819
Old Feb 8, 2002 | 03:08 PM
sacarmic's Avatar
sacarmic
Something I recommend that I think is better that dynmat is a liquid sound dampener. It is called VB-1 and is produced by Cascade Audio Engineering. Although a little more messy, I think it is easier to apply than dynmat. It's also a lot cheaper.
http://www.cascadeaudio.com/
If you also want to use the sheet based dampeners, check out Parts Express, that have generic that works pretty well.
http://www.partsexpress.com/pe/showp...ectGroup_ID=19
ttp://www.partsexpress.com/pe/showprod.cfm?&DID=7&CATID=35&ObjectGroup _ID=37
Hope that helps,
Scott
Old Feb 9, 2002 | 03:26 AM
Anguish's Avatar
Anguish
Default Re: Dynamat Alternative? (intel55)
http://www.mcmaster.com Search for High Temperature Mastic :yesnod:
What's you're actually looking for is the Polymeric Mastic Damping Sheets product # 9709T19
[Modified by Anguish, 11:33 PM 2/8/2002]
Old Feb 9, 2002 | 03:27 PM
dtorc4's Avatar
dtorc4
I bought a liquid dampner by Stinger - its blue. I don't remember the cost, but it works wonders. Messy - a little, but you don't have to worry about it coming unstuck or using a hairdryer to make it stick. It also, being liquid of course, will mold to any shape it is put on. Much better than mat. :cheers:
Old Feb 9, 2002 | 06:17 PM
intel55's Avatar
intel55
Default Re: Dynamat Alternative? (Anguish)
:lol: :lol: :yesnod:
I knew it! Yup that is the site I remember seeing previously :D :cheers:
Old Feb 14, 2002 | 10:53 PM
RandallZr1's Avatar
RandallZr1
Thanks Folks! Sorry I haven't had a chance to respond. Been too busy at work and preping the vette for the Super Chevy/Corvette Show in Houston! I'll check these out.
:cheers:
Old Feb 25, 2002 | 05:38 PM
Predator's Avatar
Predator
Cruising
At Home Depot in the roofing dept. there is this roofing stuff called Ice Guard that is what myself and friends have used. it comes in big rolls of 4' x 20' (cant remember exact size :confused: ) and runs $40. It will do about 3-4 cars and is a cheap alternative. :D
Mike
87 L98 coming this weekend. First Corvette :cool:
Old Feb 28, 2002 | 06:29 PM
RandallZr1's Avatar
RandallZr1
Default Re: Dynamat Alternative? (Predator)
Is this a type of foil backed insultation? I seem to remember seeing something like that in the home warehouse type stores but I will have to go look at the exact stuff you are talking about. Does it deaden sound AND reflect heat out of the interior???
Thanks!
Old Feb 28, 2002 | 06:45 PM
One Love's Avatar
One Love
The exact name for it is 'Ice & Water Shield' it is safe adhesive on one side and goes on just like dynamat. It comes in 4' rolls by 50' (you may be able to find small ones. It will deaden the sound but not that good of a job of heat resistant
Old Mar 1, 2002 | 06:51 PM
josby's Avatar
josby
FWIW, another possibility you might want to check into is http://www.b-quiet.com/
To Dynamat Alternative?
