Sponsored by: Innova
DDX512 random reboots
Old May 10, 2009 | 10:16 AM
lakersfan7272's Avatar
lakersfan7272
Default DDX512 random reboots
I'm having an issue with my DDX512 in my 08 coupe. Seemingly at random the unit will reboot while in the middle of listening to music via the iPod interface (I only listen via iPod so I can't comment on other sources). It comes back up normally and continues playing right where it left off.
Would this indicate a problem with the install or the the unit itself?
Old May 12, 2009 | 12:38 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Could be either one. I'd definitely recommend trying the other inputs to make sure it's not something related to the iPod connection - and I'd unplug the iPod while doing it. Also you might want to see if it happens only while the car is rolling or if it also happens sitting in the driveway. If it's only while rolling it could be your switched 12V output from whatever OEM interface you used is making intermittent contact or that interface itself may be the problem.
