Sponsored by: Innova
?? removing console in 2009 coupe?
Old May 13, 2009 | 02:30 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default ?? removing console in 2009 coupe?
How do I properly remove the console in a 2009? I want to access the area beneath the cupholder.
Old May 13, 2009 | 02:44 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
remove the torx screws in the center console compartment. remove the 7mm screws on the ebrake. remove the shifter **** and lift up. 2 minutes of work
Old May 13, 2009 | 03:21 PM
Mike02z's Avatar
Mike02z
I believe in 08 they switched to 7mm screws in the console....
Old May 13, 2009 | 04:01 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Other way 'round I think Mike. I know yours & mine are different... pretty sure the only torx on my is the console lid, the rest are 7mm so yours must be torx.
Old May 13, 2009 | 05:22 PM
Jimmy 2 Times
mine is an 08, and it does have the torx...altough, my 08 I took delivery in August of 07. They may have changed it later in production
Old May 13, 2009 | 07:20 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i have seen different combos in diff c6's
To ?? removing console in 2009 coupe?
