Sponsored by: Innova
Cheap CD changer for C5
Old Feb 5, 2002 | 07:40 PM
99HT's Avatar
99HT
Default Cheap CD changer for C5
I have confirmed that a Rockford Fosgate RFX-8601 6 disc CD changer will work in a C5. I bought one off ebay for $60 and tested with a Bose HU. This changer is built by Panasonic, but has the special software to work in a GM vehicle.
You will need to splice into the stereo harness behind the HU to connect the audio and E&C data connections. A long cable is available from the aftermarket for installing the changer in older GM vehicles. Just cut the connector off that would plug into an older Delco HU and splice the wires into your harness.
If anyone wants the connector pinout for the changer go to this link.
http://streetsound.ty.nu/man/Manuale...s/8120-IRS.pdf
Old Feb 7, 2002 | 02:04 PM
ersatz928's Avatar
ersatz928
Default Re: Cheap CD changer for C5 (99HT)
How did you stumble on that match? Do the newer Rockford Fosgate CD changers also work in a C5??
Old Feb 7, 2002 | 02:26 PM
gtragitt's Avatar
gtragitt
Cruise-In II Veteran
Cruise-In III Veteran
St. Jude Contributor
Default Re: Cheap CD changer for C5 (ersatz928)
My perception is that 99HT dosn't stumble. He uses significant intellect with significant experience and hard work to get the answer.
Old Feb 7, 2002 | 02:55 PM
99HT's Avatar
99HT
I have been researching the GM E&C bus for a project I am working on. This data bus has been used in many GM vehicles to control the stereo system, OnStar, cell phone, HVAC..etc. I happened to stumble across the specific Rockford Fosgate CD changer when I was investigating the keyword E&C using Google. I was suprised that it had a E&C bus interface. I believe that Delco supplied HU's to Rockford Fosgate, and used their standard CD changer interface bus to control the changer used in the system. For all I know, Delco supplied the changers to Rockford. They are really Panasonic units.
It was well known that the specific Rockford Fosgate CD changer would work in some older GM vehicles, it was not known it would work in newer ones also. I bought one and crossed my fingers. From what I can tell it's only the interface cable that limited it's use to older GM vehicles. Splice the cable into a C5 harness and it works.
I have the ability to bench test a C5 HU. You must have a surplus BCM to talk on the DLC buss. The DLC buss tells the HU to turn on. Without a BCM or custom PC software and a OBD II interface, the HU will never turn on outside a car.
Old Feb 25, 2002 | 11:45 AM
ersatz928's Avatar
ersatz928
I mean't nothing negative about 99HT by using the word "stumble". His answers are always well technically founded.
Old Sep 20, 2022 | 08:29 AM
Changa87's Avatar
Changa87
2nd Gear
Would you please tell me how you spliced the wires to fit the footwell plugs? Thank you
Old Dec 10, 2022 | 11:50 AM
helphos's Avatar
helphos
See! I'm not the only one to respond to TWENTY year old threads! (I'd like the answer, too! )
Old Dec 12, 2022 | 01:27 AM
jamieo's Avatar
jamieo
I doubt you get a response.Member hasn't been active for 17 years
To Cheap CD changer for C5
