Sponsored by: Innova
98 C5 Headlights Flashing
Old May 27, 2009 | 06:21 AM
jimbo1972's Avatar
jimbo1972
Default 98 C5 Headlights Flashing
I have had my 98 Coupe for a while now and bougth it with an aftermarket stereo in it. Since day one, the headlight pulse to the bass slightly at night and it has always bothered me.
Here are some specs...Pioneer Head unit, eclipse speakers, RF Amp and 10" sub in a stealthbox. Power and ground is run to the battery that is a new Redtop Optima Battery.
This winter I cleaned all the body grounds.
What do you think? Do I need another ground closer to the Amp? What about a CAP? I have a 1 farad Cap sitting on the shelf.
Thanks for the help!
Jimbo
Old May 27, 2009 | 09:06 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Look in the C5 FAQ for doing "The Big 3." The C5 wiring needs some help to support high-draw stereos.
Old May 27, 2009 | 10:30 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
big 3
Old May 27, 2009 | 11:33 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Troubleshooting:
A) Big-3 (use 4-2awg)
If the problem persists proceed to next step
B) Replace alternator with the Mexican-built 140 amp version. Most cars cane with the French-built 110 amp version. The extra 30 amps will be helpful.
C) Install a capacitor. 1 farad per 500w should be enough.
D) Replace battery
E) Install an aftermarket performance Alternator.
F) Give your car to me.
Old May 27, 2009 | 11:50 AM
jimbo1972's Avatar
jimbo1972
Thanks for the info..I will give the "big 3" a try.
I had done that on my WRX and just did it on my ATV. The ATV was not charging that great, installed a jumper from the rectifier to the battery and added additional gounding and the charging voltage went up about 1.5v. (from 13 to 14.5v)
On the WRX, it actually smoothed out the idle and the car started much quicker.
I will let you know how it works out!
Thanks again
Jimbo
To 98 C5 Headlights Flashing
