With the information that you've provided, I can offer you this: I would wire it to match the lowest compatible impedance between the subwoofer and amplifier.
Yeah?? I have it wired now bridged to 1 ch then a wire from 1 pos to the other neg, pounds pretty good, but Im not sure if thats right?? how would I do what your saying??
According to the manual that amp bridged can only handle a 2 ohm load. If you've tied the +'s & -'s of the voice coils of that sub together and wired them bridged to the amp then you're driving it harder than it's designed to be driven and you're going to burn it up.
You could wire it in series as Greg suggests or just wire each of the voice coils to separate channels on the, getting 90W into each of of the voice coils on the sub. This is the wiring Greg suggests:
Your amp would likely be putting bout 165W into the sub this way so you'd get a bit more by wiring it stereo but your enclosure may not permit it.
Hmm I know the amps been running bridged for at least 4yrs since Ive had the car and its always sounded great, When i did my dd i did some upgrading and I unhooked the sub to remove I took a few pics but when i went back to check they werent clear, I know the amp is not running in stereo currently. My interior lights are dimming now with the addition of the 4ch amp... But they never did before?? Only when the bass hits...
make sure u run the amp bridged not just off of a left or right channel
i saw someone posted the amp is 2 ohm stable bridged im pretty sure its not, only 2 ohm stable when running in stereo
Yes, it's stable @ 90x2 into 2 ohms when I looked it up.
Time to go read about "The Big 3" in the C5 FAQ.
aWESOME THANKS gUYS, SO WHAT you posted above is the correct way to run this amp?? also the link for the big 3 doesnt work, maybe my 8gge wire isnt enough anymore???
