Sponsored by: Innova
line out converter
Old Jun 15, 2009 | 04:10 PM
buckg2's Avatar
buckg2
Default line out converter
PAC-OEM VETT-1 is on back order. So to add a line out converter should I wire this in behind the stock H/U (per PENTAVOLO instruction) or in the door between the woofer and the amp?
Old Jun 15, 2009 | 05:39 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
on a C5 you DO NOT NEED A LINE OUT CONVERTER
splice the rca's in behidn the headunit its the best source for signal
IMO splicing a line out converter at the bose woofers is about the worst way to do it
