Anyone running Alpine PDX amps
Jun 18, 2009 | 10:53 AM
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
This might be a stupid question so I am prepared for some abuse
On the plug in speaker terminals is the positive at the top? Its really not that clear on the amp it self...
Jun 18, 2009 | 11:08 AM
+ and - are marked on the plugs. It doesn't matter which way you plug them into the amp, because its Outer and Inner. Not Top and Bottom.
So, it's impossible to plug them in backwards.
Jun 18, 2009 | 11:25 AM
Cruise-In V Veteran
Jun 18, 2009 | 11:27 AM
Cruise-In V Veteran
Also, the plug fits in both ways which makes is tougher to determine positive and negative..
Jun 18, 2009 | 11:32 AM
You can't plug it in wrong, even if you wanted to.
I see you have Blue wire on Positive.
So if you plugged it in with blue wire on top, then Blue would be plugged into POsitive in the amp.
If you plugged it in with Blue wire on bottom, then Blue would still be plugged into positive in the amp.
It's just like a round barrel plug that goes into a laptop, or from an A/C Adapter. There is no upside down.
Jun 18, 2009 | 11:38 AM
Cruise-In V Veteran
Quote:
Originally Posted by
Kale
Thats what I was figuring but wanted to double check before I installed this thing in the car. Thanks for the help, appreciate it
Jun 18, 2009 | 11:39 AM
any time
Jun 19, 2009 | 07:03 PM
From: ECS : WTF did you break now and HTF did you break it this time
so how do the amps sound?
I have a 4x150 new in the box that I plan on using in the ratt if I ever decide to put a stereo into it....
what did you have in there before? JL? the blue car has JL in it.
