Sponsored by: Innova
Convert Onstar to Bluetooth
Old Jan 1, 2012 | 08:28 PM
  #41
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
bump. For a 2008 C6 Coupe (non nav) - do I just buy this from costar site and I am done? I don't need anything else?
Old Oct 24, 2012 | 01:19 AM
  #42
SeeFiveOhFun's Avatar
SeeFiveOhFun
Bump. 2009 coupe, no nav. and wondering the best way to get blue tooth .... override Onstar with this bluestar contraption, or upgrade to a new stereo head unit. Thanks for help anyone can provide.
Old Oct 28, 2012 | 06:32 PM
  #43
Ed Ski's Avatar
Ed Ski
Cruising
Default BlueStar or Upgraded OnStar ???
Hey....new here so please be gentle....
What would be a better way to go to add bluetooth to my 2008 (z51 coupe) vette??
1) Purchasing the CoStar/Bluestar unit, OR
2) Upgrading the Onstar unit to one from a 2009 Z06 (Which I can get my hands on cheap).
If it is the latter, are there any configuration problems putting an OnStar from another vette in my car?
Any help appreciated, thanks!
Old Oct 28, 2012 | 08:00 PM
  #44
2 GTOs's Avatar
2 GTOs
St. Jude Donor '11-'12
A bunch of us went through this on the G8. The units had to be reprogrammed with the VIN of the new car. I don't remember if this was Bly required if you wanted to use on star as well.
If you google Chris White of White Auto and Media, he will be able to tell you. I know on the G8, when you did the swap, GM was no longer able to scan the car remotely for the diagnostics.
Old Oct 29, 2012 | 12:14 PM
  #45
Ed Ski's Avatar
Ed Ski
Cruising
Ok, I thought reprogramming might be an issue. I do not use the OnStar, so perhaps CoStar/Bluestar is a better way to go. Thanks for the info!
Old Oct 29, 2012 | 12:29 PM
  #46
HOTXFIL's Avatar
HOTXFIL
I have the CoSTAR Technologies Bluestar module in my '08 Z, have for about 2 years. I love this thing, works exactly as advertised.
- It disables OnStar completely without removing any of the components
- I have my module under the passenger seat, install/removal takes 2 minutes
- The unit's firmware can be upgraded in a couple of minutes with a USB cable/PC
- Battery drain issue was solved long ago. I've never had an issue
- Caller ID is supported in the latest firmware
If you're not sure what to get after you've gone through their website, just call or e-mail, they'll get you the right one.
I have no interest in or connection to this company. I just have one and love it.
Old Oct 29, 2012 | 12:40 PM
  #47
Ed Ski's Avatar
Ed Ski
Cruising
Thanks... I have looked into this and I located my OnStar box in the rear compartment of my Vette....BlueStar DOES look simple to install. That's what I will probably do. Thanks for the feedback!
Old Oct 29, 2012 | 04:12 PM
  #48
markcz's Avatar
markcz
If you were to upgrade to a newer onstar box that has BT on it you would also have to upgrade to a newer radio and then add the steering wheel buttons since they're what control the BT functions when you get a call. It would be easier to just replace the radio with aftermarket.
Old Jan 8, 2013 | 10:51 AM
  #49
truckplay's Avatar
truckplay
Default i just bought bluefusion for my 2005
it plugs into the xm tuner in the left rear. phone works fine, audio synch with my BB works fine but i lost my xm -- "no signal" I thought i damaged the antenna but it doesn't seem to be. if anyone has had this problem please let me know.
model # bfcl2k
thanks
Old Jan 15, 2013 | 02:41 PM
  #50
Ed Ski's Avatar
Ed Ski
Cruising
As it turned out I went for the CoStar Bluestar ...it installed in minutes and functions very well! With my iPhone and Siri connected I can even send voice TEXT messages. Very happy with the product.
Old Feb 21, 2013 | 01:56 AM
  #51
nickli's Avatar
nickli
Where is the onstar unit in a 2008 vert?
Thanks!
Old Feb 21, 2013 | 10:50 AM
  #52
98Pace's Avatar
98Pace
St. Jude Donor '12
Thanks!
If it's the same as the 08 coupe, it's in the rear pocket on the passenger side. I pulled the carpet and lid up a bit and removed the inner liner of the pocket to get to the onstar box. Had to loosen up the wiring harness a bit to get enough slack to be able to mount the Bluestar somewhere that it wouldn't interfere, but it was an easy install (if that's what you're doing).
Old Feb 21, 2013 | 03:24 PM
  #53
Ed Ski's Avatar
Ed Ski
Cruising
I could not find a place to neatly fit it concealed behind the inner lining, but I do not use the compartment for storage, so I just left the BlueStar in the compartment and switched the plugs over.
Old Feb 21, 2013 | 04:23 PM
  #54
98Pace's Avatar
98Pace
St. Jude Donor '12
I ended up mounting mine right beside the Onstar module on the front wall of the pocket, closer to the fender of the car. It's a bit snug as the liner sticks out just a bit there, but once I separated out the wires for plugs 3 and 4 I was able to fold the wires for plugs 1 and 2 far enough to be able to fit the Bluestar. I think it will stay in place with the liner pushing it against the wall of the pocket and a little bit of double sided tape.
