Sponsored by: Innova
calculating amp efficiency?
Old Jul 1, 2009 | 11:35 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default calculating amp efficiency?
How do I calculate an amp's effeciency?
Assuming a 100% effeciency amp would suck the same amount of amperage as the total of the reccomended fuses, I'm looking to find out the effeciency of my new MRP F300 amps so I can calculate how much power they will suck.
Old Jul 1, 2009 | 11:51 PM
Kale's Avatar
Kale
They are class a/b right? assume 55% to be safe.
But you fuse for wire, not for amps.
Old Jul 2, 2009 | 12:12 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The power ground wires are plenty big, I'm trying to see how hard my power converter will be working to power the system. I've upgraded from a 55 amp model to a 75 amp. It will be running (2) 300 watt full range amps and my JL 500/1
To calculating amp efficiency?
