Sponsored by: Innova
bose wiring
Old Jul 10, 2009 | 12:43 PM
Lancejoker's Avatar
Lancejoker
Default bose wiring
Is it worth it to pull out all the Blows wiring when running new wire for audio?
Old Jul 10, 2009 | 02:48 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No.
The wiring for the bose stereo is integrated with the factory wiring harnesses, you have to re-wire a bunch of your car.
BTW, you'll get a "U" code no communication when you swap out the head unit for an aftermarket unit.
Old Jul 10, 2009 | 05:05 PM
Lancejoker's Avatar
Lancejoker
U code if not connecting to the factory harness,correct?
Old Jul 10, 2009 | 05:29 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
"U" Code if not using a factory head unit. (aka Stock Radio).
The Corvettes use a data line that registers them with the BCM and you will no longer have this when you use an aftermarket unit.
Old Jul 10, 2009 | 06:16 PM
Lancejoker's Avatar
Lancejoker
No way to get rid of it?
Old Jul 10, 2009 | 06:30 PM
Mike02z's Avatar
Mike02z
I honestly have no idea what you guys are talking about with this "U" code stuff but I can tell you that you certainly can replace the factory radio with an aftermarket radio using an integration kit that will work flawlessly with the C5 and C6.
I would not try and remove any existing wiring. I would use a factory integration module and rewire for aftermarket amps and speakers.
Old Jul 10, 2009 | 06:33 PM
Lancejoker's Avatar
Lancejoker
To be honest,this is the first time I have seen the "U" code issue.
Old Jul 10, 2009 | 07:08 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's not and issue and won't give you a code unless you pull codes. I'm just giving you a heads up.
Old Jul 11, 2009 | 10:33 AM
Lancejoker's Avatar
Lancejoker
Thanks. I appreciate it.
Old Jul 11, 2009 | 01:19 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Not a problem.
To bose wiring
