Sponsored by: Innova
C5 bose amp location?
Old Jul 19, 2009 | 01:08 AM
209TIME!!!'s Avatar
209TIME!!!
Default C5 bose amp location?
CAN SOMEONE PLEASE TELL ME the location of the C5 Bose amp/amps and would you happen to know the wire color codes that go to the amp
thanks for any help....
Old Jul 19, 2009 | 01:31 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
each door has a single amp that is only for the door sub
Old Jul 19, 2009 | 03:14 AM
209TIME!!!'s Avatar
209TIME!!!
Okay thanks....so how can i make those amps work with a aftermarket deck? some people say you need the harness with the chimes and some say you dont. other people say just use a line converter, im so damn confused i dont know where to start....do you have any tips?
Old Jul 19, 2009 | 05:31 AM
markcz's Avatar
markcz
Much good info here. Schematics and plug pin-outs are avail in post #96 if you need them.
If you just want to swap out the radio you'd need an ROEM-Vet1 and an adapter plate for the new radio. HUmount.com for fancy custom plates, or a generic plastic one will work just fine.
To maintain RAP you'd need something like this, or you can find ignition switched power in the 3-wire pigtail next to the I/P fuse box for free.
Old Jul 20, 2009 | 12:44 AM
pentavolvo's Avatar
pentavolvo
gmcrv2
To C5 bose amp location?
