Sponsored by: Innova
Best interior ground location for C6?
Old Aug 1, 2009 | 12:01 AM
C5 Hardtop's Avatar
C5 Hardtop
Default Best interior ground location for C6?
So I'm doing a Kenwood DNX9140 with remote steering wheel controls installation. The stock amp and speaks are not touched.
So should I use the ground wire from the PAC wire harness to ground the Nav and remote steering wheel control harness?
I've been reading that folks almost always use the ground loop isolator (a couple of them for some folks). So I'm wondering if I should divert the ground wires for the harness, remote steering wheel control adapter harness and Nav/radio grounds to a grounding bolt.
I looked at one install and a fellow was grounding at the amp location at the bottom bolt right hand side near the fuse box. I just checked this out on my car ('08 Z) and it looks to me like the bolt goes into a clip and the clip is connected to a frame that isn't metal (or maybe it is?).
Then I thought, maybe I should run a wire to this aluminum brace thing inside the dash near the glove box. But I don't know if that is a frame ground or not.
Another thought was to run the damn ground wire to the battery in back of the car (Z06) and that may be the "best" but the most time consuming.
Also, I only have 16 gauge black wire so I'm going to double up. Will that be enough ground lead?
So what's the best ground location if I don't have ground loop isolators?
Any input is appreciated!
Old Aug 1, 2009 | 04:59 PM
C5 Hardtop's Avatar
C5 Hardtop
I'm just going to use the black wire ground on the PAC 24b and wire the grounds to that. Hopefully this will work w/out alternator hum/whine as I don't know where to hook up a ground loop isolator since I'm not using RCA jacks.
Old Aug 1, 2009 | 08:32 PM
fred96ws6's Avatar
fred96ws6
I just did the DNX8120 on my 08. There is a 10mm bolt at the bottom of the glove box all the way to left about 1" from where it meets the center console. That is where I have all my grounds and have no hum or whine. I used 1 16 gauge wire with no problem.
Old Aug 1, 2009 | 09:22 PM
C5 Hardtop's Avatar
C5 Hardtop
well, I used the gm24b ground wire and hooked all ground leads up to that using solder.
It turns out there is no whine at idle or when reving, but I didn't drive the car. Hopefully there is no difference where driving has whine where idle doesn't.
To Best interior ground location for C6?
