Sponsored by: Innova
iPod Connector
Old Aug 7, 2009 | 09:42 PM
Texan07's Avatar
Texan07
Default iPod Connector
Kenwood DNX 9140 iPod cable, will the Kenwood KCA-iP301V cable work with the newer iphone 3g and ipod touch which has the 3.0 upgrade, talking about the charging function while connected.
David
Old Aug 7, 2009 | 10:04 PM
Mike02z's Avatar
Mike02z
David
I can tell you that it works with the 2nd gen iTouch's which are pretty similar to the iPhone in design. Mine also plays videos which the manual says they won't on my 6140. My itouch charges as well so I'm sure so will the iPhone since they use the same power pins.
Old Aug 7, 2009 | 10:22 PM
Texan07's Avatar
Texan07
Mike did you install the lastest firmware for the iPod touch,
Old Aug 7, 2009 | 10:31 PM
Mike02z's Avatar
Mike02z
I have version 2.2.1 currently. I'm installing 3.0 now. I'll let you know tomorrow if it still charges. I doubt that fw would stop that since it can't change the pins that are used for charging but I'll get back to you.
Old Aug 7, 2009 | 11:15 PM
Mike02z's Avatar
Mike02z
I went out to my car and my iTouch still charges with 3.0 and DNX6140.
Old Aug 8, 2009 | 01:33 AM
markcz's Avatar
markcz
If a newer ipod device won't charge on a car setup all you need is an adapter (also available at stores like Target and wal-mart).
Old Aug 8, 2009 | 01:55 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
will work just fine
Old Aug 8, 2009 | 07:34 AM
Texan07's Avatar
Texan07
That's good new's, and I will look into the Scosche adapter for my other car which has the older adapter.
To iPod Connector
