Sponsored by: Innova
Metra Dash Bezel
Old Aug 11, 2009 | 05:31 PM
Texan07's Avatar
Texan07
Default Metra Dash Bezel
Working on finishing up my DNX 9140 install down to the Metra bezel and it appears its not the correct one (Metra 95-3304) the reason I say this is I'm having trouble getting it to line up correctly , See attached link for pictures.
http://picasaweb.google.com/lh/photo...eat=directlink
Old Aug 11, 2009 | 05:43 PM
C5 Hardtop's Avatar
C5 Hardtop
check out this pic and note the prong thingamajigs that go from the inside out (where the bolt goes)
In that picture, the unit is upside down so install it accordingly
Old Aug 11, 2009 | 06:32 PM
Mike02z's Avatar
Mike02z
The side pieces attach directly to the HU with the 90 degree wings towards the front of the HU. You then put the unit in and place the rectangle piece on top and put the screws through both pieces of plastic. It looks to be the correct kit.
Old Aug 11, 2009 | 07:58 PM
MI_ZO6's Avatar
MI_ZO6
St. Jude Donor '08-'09-'10
It's the right kit. Install the brackets into the faceplate by installing the short leg of each bracket through the slots in the faceplate. The bracket is installed with the short leg facing the outside of the faceplate (not inwards). If installed properly, the holes in the bracket will line up with the holes in the faceplate. If they don't, switch the brackets to the opposite side. Good luck!
Old Aug 11, 2009 | 08:28 PM
Texan07's Avatar
Texan07
Default Metra Bezel Fitment
Here are a few picture with the ill fitting Metra Bezel with the radio mounted and not, with console and without.
Old Aug 11, 2009 | 08:37 PM
MI_ZO6's Avatar
MI_ZO6
Note my previous post. You have the short leg of the bracket BEHIND the flange of the face plate. You'll need to remove the screws holding the bracket to the HU, and install the short leg of the bracket through the slots in the faceplate. When done correctly, the short leg of the bracket will be in front of the faceplate flange.
Old Aug 11, 2009 | 08:41 PM
MI_ZO6's Avatar
MI_ZO6
By the way, the slot I'm referring to is shown quite clearly in your photo #3!
Old Aug 11, 2009 | 08:50 PM
Texan07's Avatar
Texan07
Default Bezel
MI-Z06 I guess I was trying just to hard and not thinking, when I read your first reply a light went off, man to I feel like a Dumb ***. Thanks for the reply. The people on this forum are great folks to put up with the one's like me.
David
Old Aug 11, 2009 | 09:08 PM
MI_ZO6's Avatar
MI_ZO6
No problem. It would be nice if Metra included some instructions. I know I scratched my head for a little while when I opened the package and tried to figure out how the parts went together.
Guys on this forum have always gone out of their way to help me when I've posted questions, and I'm happy I could give you some assistance.
Good luck with the rest of your install!
Old Aug 11, 2009 | 09:34 PM
CraigE's Avatar
CraigE
As I recall, when I installed my 9140,
the brackets stamped L & R had to be reversed.
I would think that L = DS and R = PS.
However when reversed, it worked.
Good Luck,
To Metra Dash Bezel
