Sponsored by: Innova
C4 Radio Install Question
Old Aug 15, 2009 | 08:01 PM
Julioengineer's Avatar
Julioengineer
Default C4 Radio Install Question
To start I have a 1996 vette with the bose system. I have bought the PAC OEM-1 adapter so I can keep the Bose speakers with an after market head unit. From what I have read it seems to me I need to run wires for 4 speakers, power, ground, antenna, and 12 volts to behind the passenger seat where the reciever/tuner unit sits. Do I also need an antenna extension? I also need a VSS wire for my GPS. Is this in the harness that goes to the radio or the reciever/tuner behind the passenger seat. I have also seen what appers to be a harness behind the radio in the dash. With all the research I have done I am a little confused now. Do I use the OEM-1 behind the radio or behind the passenger seat? Any help will be appreciated.
Old Aug 18, 2009 | 07:39 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I would think that everything but the antenna extension would run through the PAC.
