Sponsored by: Innova
C4 Subwoofer interface to Bose
Old Aug 16, 2009 | 01:35 PM
secondchance's Avatar
secondchance
Default C4 Subwoofer interface to Bose
A question for audio gurus out there;
I have a 94 w/ factory Bose. Ultimately I will be going to after market system. In the meantime, I have an old Alpine mono amp and a 10" sub that's been sitting on the shelf from one of my former rides.
I was thinking about building a enclosed box and tapping off left and right rear factory speaker w/ interface that adjusts cross over htz and hooking up to sub amplifier. I did this with other cars but they were typical 4 ohms system.
Would same hook up work with Bose 2 ohm system?
Old Aug 22, 2009 | 03:37 AM
VenkmanP's Avatar
VenkmanP
You can run an amp off the rear channel CDM outputs. It just needs to be able to handle very low signal level.
Trying to take the signal from the output of the bose amps will require signal conditioning and impedance matching and just doesn't make any sense anyway since you don't need the rear speakers once you add the sub.
Old Aug 22, 2009 | 12:03 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
get a peripheral sven2 and tap the input side of the bose amps, or just try splicing rca's in
Old Aug 25, 2009 | 12:15 AM
HowlinC5's Avatar
HowlinC5
I did it in my '96 and was quite happy with it for a while i removed the rear speakers and built a custom panel for 2 8's. They fit perfectly in the "box" area where the stock speakers were. I used a line level converter, i think thats what its called and just came off the speaker wires for the rear speakers as they came off the amp.
To C4 Subwoofer interface to Bose
