Sponsored by: Innova
ignition power wire for stereo
Old Aug 29, 2009 | 02:29 PM
webdzynes's Avatar
webdzynes
Default ignition power wire for stereo
Where are you guys hooking up your ignition power for your stereo? I need to have the wire that only allows power when the ignition is on.
I had a "friend of a friend" who does this for a living install some JL audio amps with the aftermarket GM harness made just for this (stock head unit) and now, the system is drawing 70 amps - when the car is OFF! I'm guessing he didnt wire the amps to the live wire that is only hot when the car is on but rather to a wire that is always hot.... So, before I get in there, anyone know what wire runs only when the the car is on that i can tap into for the amps? (its a 06 - CO6)
Old Aug 29, 2009 | 05:34 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
drawing 70 amps is a big issue regardless if the stereo is playing or not, at anything other then high volume levels u shouldnt be drawing near this
are the amps turning off when the car turns off there should be a light on the amp
read the c6 faq it address where you can get switched power
Old Aug 29, 2009 | 11:12 PM
webdzynes's Avatar
webdzynes
The amps appear to go out when the interior lights go out. heres the funny thing - I disconnected 1 amp and the 70 amp draw goes away. It is the same amp that powers the door chimes....Could the amp have a defect causing this?
Old Aug 29, 2009 | 11:37 PM
mcgilles's Avatar
mcgilles
you must be reading your ammeter wrong! could it be drawing 70 mA? an amp would not draw 70A when not playing unless it had a low resistance short in it, in which case the amp is bad.
Old Aug 30, 2009 | 02:16 AM
markcz's Avatar
markcz
That's my bet, 70mA not 70A. The Fluke 87 that I use at work is only rated for 10A, so unless you used a clamp on meter (which I generally don't trust as being super accurate) your meter may be fibbing to you.
Have you seen my post in your other thread? Sounds like the installer used the correct wire.
If you really are drawing more than a few mA of current, most definitely YES.
As I see it you have 2 options...
1 - Connect the new amps to a true 'ignition switched' wire (you'll lose RAP on the new amp)
2 - Make sure that you are only pulling 70mA, and leave everything as it is. If the radio is off the amps won't need much power at all to stay on for a few minutes, the battery can take it as long as you drive the car on a regular basis.
Old Aug 31, 2009 | 08:45 AM
webdzynes's Avatar
webdzynes
Actually, I didnt personally run the ampmeter test. The car was having a "Service Charging System" reading popping on and off (which also happened last year) and ultimately wouldnt turn over at all. I had to have it flatbedded to the dealer. I suspected it was the starter again, just like last year but the technician said no, it was because the battery was drained. He disconnected the hot wire to the amp and said the drain went away. Accordingly, he concluded it was the amp. Odd thing thing is, the set up was done 3 years ago and nothing was ever altered since then.
I suppose it is certainly possible it was draining 70mA. It was the service writer that told me 70 A so I will try and check back with him...
Would a 70mA constant draw do this though? I drive the car 3-4 times a week...
Old Aug 31, 2009 | 05:19 PM
markcz's Avatar
markcz
Sounds like the amp may have gone bad, but without putting a meter on it myself that's just a guess.
One thing that does come to mind, you need a smaller fuse on that hot wire
To ignition power wire for stereo
