Why is auxbox needed for C5 radio aux inputs?
Does anyone know why an auxbox, pxdx or similar is needed to use the aux inputs on a C5 factory radio? Why couldn't I order a PXHGM4 harness, cut off the end which plugs into the pxdx and solder on a mini-headphone jack or cable to connect to an external device? I'm not looking for control or charging capability, just a way to feed an external source into the radio.
The gizmos simulate a changer being installed. The radio doesn't have an aux input that can just be selected. You need to have something there that makes it think a changer is connected and playing, then substitute the new audio for what should be coming from the changer. Does that make sense? I guess the radio is just too 'smart' to try to play something that it doesn't know is there
If you have an actual changer already installed you can do something similar to what you're asking, click here for that schematic.
Simulating CD changer
Yes, I suspected that there must be some sort of signal to tell the H/U that a changer is attached, but I doubt that it's any sort of complex signal. It's most likely simply a voltage or a ground applied to a specific pin, maybe a resistance between two pins. I strongly doubt that it's anything so complex it requires $75 or so worth of electronics to pull it off. The problem is figuring out what it is. Anyone ever opened up an auxbox or one of the other devices? Pics of the inside, if anyone has them, would be wonderful.
its more complicated then you think
check out ls1tech there is a how to add an aux input by doing some splicing inside the radio it also works on the vette
Other than the audio & power wires there's only one serial data wire that the radio and changer use to communicate with each other. Check out the schematics here to see for yourself.
Sometimes you even have to jump through hoops to get the radio to 'recognize' a stock changer. The aftermarket units make it even more finicky.
