Sponsored by: Innova
LockPick 360 problem..
Old Sep 19, 2009 | 11:29 AM
NOLA-ZR1's Avatar
NOLA-ZR1
Default LockPick 360 problem..
Hi all,
My lockpick 360 has been working fine for several weeks. I have a back-up camera and the i-pod connected to it and everything was great.
Went for a drive and my screen is black. Radio works, just black screen. I searched the forum, but didn't find any related threads.
Anyone have any idea what's up? Did that ribbon in the back of the radio come loose? Thanks..
Old Sep 20, 2009 | 10:25 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
If you have factory NAV then you may have just encountered a normal bug. Every now and again it will do this. Shut the car completely off and start it again, usually clears right up. Could very well be it has nothing to do with the 360.
Old Sep 21, 2009 | 10:01 AM
NOLA-ZR1's Avatar
NOLA-ZR1
You may be correct. I decided to take it to the shop to see if they can pull the radio out and check the ribbon. Wouldn't you know it, it worked fine again........
To LockPick 360 problem..
