Sponsored by: Innova
radio guys
Old Sep 28, 2009 | 09:35 PM
tomsws6's Avatar
tomsws6
Default radio guys
hey, not a vette but i have a nakamichi radio amp and speakers out of my old lexus gs400. anyone know if i can hook the amp or atleast the speakers with out using the actual lexus radio itself to a 97 transam?
Old Sep 28, 2009 | 09:47 PM
secondchance's Avatar
secondchance
First I would run search on the internet and see if it's 4 ohms or 2 ohms system you had in the Lexus.
I am not that familiar w/ 97 TA but if Bose system than it may be 2 ohms. Base Delco most likely is 4 ohms system.
It may be best to stop by Car Audio shop and talk to an installer.
Old Sep 28, 2009 | 10:03 PM
tomsws6's Avatar
tomsws6
the T/A has that monsoon system and that i believe is 2 ohms and the nakamichi is 4 ohms. Not sure really what that means ( ohms ). btw thanks for the help
Old Sep 28, 2009 | 11:06 PM
secondchance
If different ohms speakers are not interchangeable. I am no electrical engineer but ohms is a measure of resistance in electrical circuit. Speakers are designed based on a particular ohms - home audio, I believe runs 1 ohms, typical car audio (of the shelf head units) are designed around 4 ohms and some "designer label" car audio such as Bose in Vettes, at least C4s, are 2 ohm system.
Old Sep 29, 2009 | 11:33 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
is it a factory amp or aftermarket, if its an oem amp prly not worth ur time
Old Sep 29, 2009 | 12:33 PM
secondchance
I think he is talking about a Nakamichi amp that was installed at Lexus factory.
Old Sep 29, 2009 | 12:43 PM
pentavolvo's Avatar
pentavolvo
well if thats the case its prly not worth trying to keep it, finding proper molex plugs could be trouble plus the TA system is very non standard setup
To radio guys
