Sponsored by: Innova
Help only driver side speakers work
Old Oct 16, 2009 | 11:32 PM
03redzo6's Avatar
03redzo6
Default Help only driver side speakers work
well today i was at the exhaust shop getting my exhaust welded, when i took off i noticed only my driver side speakers were working, so far ive only checked the amp fuses/radio fuses and they are fine, are there any other fuses i should look for. i also started moving the speaker connections on the amp, if i move the passanger side connections to the driver side they work but then the driver side speakers wont work. could it be that the amp shorted out when they were welding the exhaust.
my other question is if the amp did short out could i connect both driver and passenger front to one connection and driver/passanger rear to the other connection
