Sponsored by: Innova
Front or back speakers
Old Oct 19, 2009 | 08:03 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
Default Front or back speakers
I am installing a Kenwood KSC-SW10 self powered woofer in my 09 coupe. The install instructions say it can be installed either to the fron speakers or the rear speakers. Question for any of you guys that know something about audio. Which should I conect them too?
Old Oct 19, 2009 | 08:42 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Originally Posted by LOUSVETTE
I am installing a Kenwood KSC-SW10 in my 09 coupe. The install instructions say it can be installed either to the fron speakers or the rear speakers. Question for any of you guys that know something about audio. Which should I conect them too?
For the C6 you really can't use either and get the best results, but do NOT use the rear speakers. The rear speakers are high passed in both the Delco & Bose system so you will not get the very frequencies you need to drive your subwoofer. If you're not going to grab the RCA signal from the head unit (check the C6 Audio FAQ for info on this) then I guess you could grab signal from one of the door subs, at least you would have the right range.
Old Oct 19, 2009 | 09:08 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
u really need to grap an rca signal from radio output or the input of the amp otherwise its gonna sound like garbage
Old Oct 19, 2009 | 01:29 PM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
And thats posible with this Y connector? PAC ADD-GM24
Old Oct 19, 2009 | 02:30 PM
pentavolvo's Avatar
pentavolvo
yes or a quick splice job
Old Oct 19, 2009 | 02:39 PM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
Thanks Komoman & pentavolo for your help
Old Oct 22, 2009 | 11:18 PM
reddoor123's Avatar
reddoor123
I have directions for add-gm24.
Where can i find directions for splicing to speakers?
Old Oct 23, 2009 | 12:05 AM
reddoor123's Avatar
reddoor123
Old Oct 23, 2009 | 06:39 AM
pentavolvo's Avatar
pentavolvo
not splicing speakers, behind headunit or at oem amp its all the same wires the add-gm24 uses
To Front or back speakers
