Sponsored by: Innova
C5 2003 Corvette speed sensor location?
Old Oct 20, 2009 | 06:01 PM
der451b's Avatar
der451b
Default C5 2003 Corvette speed sensor location?
Hello everyone.
I am going to install Kenwood in dash GPS navigation to my Car, this project need to tap the GPS wire to speed sensor wires.
Does anyone point me where is the speed sensor connector? Speed sensor wire color ?
Very best regards,
Old Oct 20, 2009 | 06:14 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
its listed in c5 faq, you can grab it at the guage cluster plug
last i knew the kenwoods didnt need VSS
Old Oct 20, 2009 | 06:31 PM
der451b's Avatar
der451b
I got the Kenwood Excelon KVT-614 with GPS module KNA-G510.
The instruction said that I need to tap GPS wires to Speed Sensor. The instruction paper in print in BW , show connector in BW no wire color code.
Old Oct 20, 2009 | 06:40 PM
pentavolvo's Avatar
pentavolvo
i didnt recall the g510 having vss but its been a while regardless you dont really need it
Old Oct 20, 2009 | 06:44 PM
der451b's Avatar
der451b
So I don't really need to tap to Speed Sensor wires?
I just want to make sure I understand the procedure before I open up the Dash board.
Regards,
Old Oct 20, 2009 | 07:11 PM
der451b's Avatar
der451b
You are correct, KNA-G510 need no VSS.
I looked at the KW Instalation Manual , there is no VSS wire.
Many thanks.
To C5 2003 Corvette speed sensor location?
