Been finding lots of people lately looking to go very stealthy and unless you have a z06 where you can hide an amp under the seat you dont have many options to hide the amp.
I know a few others have done this also but I came up with the idea of an 8" sub and 4 channel amp (power sub and door component speakers) under the center cubby. Obviouslly the box would need to be carpeted but this is an idea, I through together for a few diff customers.
If you want to put the stock cover back on there may be an overheating issue. I briefly had a 6" powered Bazooka and a 4x25w amp hidden back there in my C5, they were fine for a while, but after a few hours the amp would cut out.
what about moving the latch mounting points up 3/4" and putting point supports/3/4" spacers around the underside of the cover. then you would have a 3/4" opening all around and it would be very stealthy.
That's why I love this Form. Too many minds, is a good thing.
That's a good idea. I even thought of a small 12 volt fan? Thoughts? Mark
