Sponsored by: Innova
Radio signal bleeding
Old Nov 15, 2009 | 03:56 PM
napacruzerc5's Avatar
napacruzerc5
Default Radio signal bleeding
Have a 2001 C5 coupe with the OEM Bose radio. I usually listen to sports radio whenever I drive the vette to work. Part of my commute takes me through a section of freeway (Hy 37 in CA between Vallejo and Marin) where I can hear 2-3 AM stations at a time; none of them clearly. There are also a lot of high tension wires in the area. I don't have this problem in my DD Nissan nor in my wife's C6. Rear hatch glass is heavily tinted on the C5 while neither the Nissan or C6 has non-factory tint. Saw a post somewhere blaming tint for some radio interferance. Thoughts?
Old Nov 17, 2009 | 02:41 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
If a car does not have an aerial antenna, the antenna wires are usually embedded in the rear window. If you cover those wires with a tint that contains metallic particles, then the radio reception can be affected.
AM can be affected by a lot of things, high tension wires, bridges, mountains, buildings, etc.
Is there an FM or SIRIUS-XM alternative you an listen to?
