Subwoofer Advice Needed
I listen to mostly classic rock, some hard rock, and some heavy metal. I do not blast the volume, but I do like good clear sounding audio.
I was originally planning to install a single 10" ID10d4 v.3 in a custom box that would go behind in the seats. However, a friend mentioned that it may be better using 2 8" subs since the box could be thinner and would look more balanced.
If I were to go that way I would probably use 2 Polk MM840's in a box that would resemble the Vette Partition only built to have the correct airspace.
My two questions are;
1. Is it better to use one larger sub than 2 smaller ones.
Will one larger sub give better sq than 2 smaller subs. I am not really going for spl as I don't blast the volume.
2. If I use two subs, do I put them in the same airspace or do I make a separate box for each. If I use the same airspace, do I need to double the airspace. ie. if each sub needs .4 cu/ft, do I need to make the box .8 cu/ft. Or is .4 cu/ft good with both subs in the same box. Is it better to keep them in their own box.
Thanks for any advise or insight.
I would go for the 8's personally.
Also the box will need to be .8 cubes if each sub needs .4
Having them share airspace isnt really an issue, its not necessary to seperate them
http://www.parts-express.com/pdf/295-456s.pdf
13" is really to big for what I want to do. I want to keep everything behind the seats without losing anything rear of the roof holders.
Is it better to go with a single 10" subwoofer, or will two 8"s give a better sound. By better sound I mean, tighter bass, lower freq. response, and more "feel" of the bass.
I know these are somewhat subjective. I like deep bass, but not where it gets so much you can't hear the mid or highs.
Also, is it better to aim the subs up, forward, down, or backwards. I know you should not really hear where the sub is, but I was wondering if direction made much of a difference.
thanks for any guidance.
The 13tw5 mentioned above, while it is a 13" sub, is a thin sub at only 2.5" deep. It also only needs .8 cu/ft of box. That should work well for what you are describing to want. It's not cheap though, around $500 I think. I have heard one in a friends car and it sounds very good IMO.
My opinion, the 13tw5 at more than twice the price of the IDQ is not worth it. I'd just go with the IDQ.
I was calling around a few audio shops looking for the discontinued Image Dynamics IDQ10V2D4 subwoofer. Then I happened to talk to this guy. Next thing I know he asked me how I got his number. I just said from the web. He said his shop happens to be one of the top ten shops in the country, and he happens to be the owner of this shop. He was a very nice guy and seemed very knowledgeable.
I told him I was planning to use the OEM Bose no Nav headunit, add amp, new speakers, and a box for a 10 inch sub. The box would have about 0.65 cubic ft.
His recommendations are as follows: Better to use 2-8s with that much cubic space. He said 0.65 might be enough for a 10 but it's more ideal for an 8. And that if I use 2-8s, most people will think I have 2-10s in the back if I pick the right subs. And since you mentioned Image Dynamics, he said his favorites are the ID8V3. He said he recently did an install for an ex-CEO of GM using 2-8s and the guy called back later to say he loved the system.
He mentioned that if I were to use one 10, I should get the 2 ohms dual coil version and wire in series so the amp sees 4 ohms. I didn't know that. I was going to get the 4 ohm DVC version. You can see I'm still learning. I didn't get a chance to ask him that if I were to go with 2-8s, should I get 2ohm or 4ohm DVC.
Finally, he suggested I use this Audiocontrol product:
http://rs.audiocontrol.com/company_3...les%20Note.pdf
If you want a really good deal on some brand new JL Audio 13TW5 look here
http://forums.corvetteforum.com/c6-p...brand-new.html
So anyone suggestions for me thx
