Sponsored by: Innova
Question about GM PAL install
Old Dec 31, 2009 | 02:12 PM
CENT Z06's Avatar
CENT Z06
Default Question about GM PAL install
I'm almost finished with the GM install and I'm stuck at trying to get the connector on the left side apart in order to remove the K pin.
Has anyone been able to take the connector apart, or just cut the wire and leave the connector in the plug?
Old Dec 31, 2009 | 02:31 PM
markcz's Avatar
markcz
While you do need to tap into that wire, it doesn't have to be under the dash. Check out the large paragraph in THIS old post of mine.
Old Dec 31, 2009 | 02:42 PM
CENT Z06's Avatar
CENT Z06
Thank you for the speedy reply. I'll see if that's any easier.
To Question about GM PAL install
