Sponsored by: Innova
Component speaker question
Old Jan 6, 2010 | 05:00 PM
wvufan1965's Avatar
wvufan1965
Default Component speaker question
why are most of these two way systems and not three?
How do the two way component systems compare to the three way 6x9 for sound quality?
thanks
Old Jan 6, 2010 | 06:42 PM
parboy's Avatar
parboy
2 way component system is easier to integrate in most cars. A 3 way set requires good planning and tuning to get it sounding it's best.
There is no comparison between a good 2 way component set and a 6x9. Take the component set every day and twice on Sunday
Old Jan 6, 2010 | 08:24 PM
Lancejoker's Avatar
Lancejoker
Not to mention that a 3 way system is a lot more custom work to get it to fit and some people just don't want to go thru that.
Old Jan 6, 2010 | 09:38 PM
wvufan1965's Avatar
wvufan1965
so a 2 way boston Acoustic component system will sound better then their three way 6x9?
thanks for the help
Old Jan 6, 2010 | 09:40 PM
Lancejoker's Avatar
Lancejoker
Are you talking about component or coax setups? Big difference between the two.
Old Jan 6, 2010 | 11:31 PM
wvufan1965's Avatar
wvufan1965
There are these:
BOSTON ACOUSTICS SR60 6.5" CAR STEREO COMPONENT SPEAKER
SPECIFICATIONS
Speaker/Subwoofer Size : 6.5" (6-1/2")
Design : 2-Way Component Speakers
Power Handling (RMS) : 85 Watts
Power Handling (MAX) : 250 Watts
Power Handling (Combined) MAX : 500 Watts
Sensitivity : 90 dB
Frequency Response : 45 - 22k Hz
Impedance : 4 Ohms
Mounting Depth : 2-7/16
and these
BOSTON ACOUSTICS SR95 6X9" CAR AUDIO STEREO SPEAKERS
SPECIFICATIONS
Speaker/Subwoofer Size : 6" x 9"
Design : 2-way
Power Handling (RMS) : 75 Watts
Power Handling (MAX) : 200 Watts
Power Handling (Combined) MAX : 400 Watts
Sensitivity : 92 dB
Frequency Response : 35Hz-20kHz
Impedance : 4 Ohms
Mounting Depth : 2-5/8" (67.0mm)
thanks again for the continued assistance
Old Jan 7, 2010 | 01:03 PM
fej's Avatar
fej
Two way solution for better quality sound IMO, as asking a 6x9, which is an inefficient and non-linear speaker, to play from 35hz to 20khz, is just not realistic. You may get a little more bass output from the 6x9 over the 6.5", but your clarity will suffer.
Asking for full sound reproduction from a single speaker is like asking for a 1000hp motor that lasts 500k miles and gets 50mpg.
Fej
To Component speaker question
