Sponsored by: Innova
New install question
Old Jan 31, 2010 | 07:02 PM
bowtiebubba's Avatar
bowtiebubba
Default New install question
When doing the wiring from the head unit harness to the cars harness, what or how do you do the connections? Do you use some type of connector or solder the wires? I thought about using some sort of connectors that plug into each other so if & when i would change head units i could just unplug the wires. Is this a good idea?
Old Jan 31, 2010 | 07:54 PM
drivinfast's Avatar
drivinfast
Those are butt connectors.
I used crimped connectors
Old Jan 31, 2010 | 09:44 PM
bowtiebubba
Is it okay to use the plug in type instead of the crimp type?
Old Jan 31, 2010 | 11:18 PM
markcz's Avatar
markcz
You can use anything you want to, it's your car
For car stereo connections I usually use butt splices, but I use them like wire nuts. I'll twist the wires together (like I was going to use a wire nut) then crimp on one end of a butt splice.
Most of the plug-in type connectors will use crimps on one end to attach the wires, which creates three possible places for the signal to fail, so be sure to crimp the snot out of the wire end of the fittings and also make sure the connection parts have a snug fit.
Old Feb 1, 2010 | 02:35 PM
ThissenW's Avatar
ThissenW
I prefer to solder the connections. It takes a little longer, but they're more reliable.
Old Feb 1, 2010 | 03:53 PM
nearwater's Avatar
nearwater
Same here.
Dan
Old Feb 9, 2010 | 05:23 PM
Slammed Vette's Avatar
Slammed Vette
Cruise-In II Veteran
Cruise-In III Veteran
Solder and heat shrink for a professional looking install!! Only take a few minutes longer and will stay connected
Old Feb 9, 2010 | 07:06 PM
bowtiebubba
Im going to go ahead & solder, heat shrink, the wires together.
Old Feb 9, 2010 | 07:16 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
solder and tape or heatshrink is the right way to do it
To New install question
