Sponsored by: Innova
A few wiring questions
Old Feb 21, 2010 | 06:24 PM
bowtiebubba's Avatar
bowtiebubba
Default A few wiring questions
The antenna wire on a coupe,the instuctions say to wire to the antenna booster power control terminal. Where is that?
Where do you wire the reverse signal wire too?
What gauge wire is the normal speaker wire?
Where is a good place to mount the HD radio module?
Does the face plate come off of the HVAC control unit?
Thankns,Guys
Old Feb 21, 2010 | 09:12 PM
markcz's Avatar
markcz
A cut/paste from C5 FAQ post #9:
The coupe uses an amplified module to combine the windshield and hatch antenna leads before they connect to the HU. That module is powered by both 12V and 5V from the stock HU, the 12V is constant and the 5V is only present when the radio is playing. Aftermarket radios only supply the module with the 12V signal, click here and scroll down to post #4 to see how you can once again power your antenna module amplifier.
In C5, most just run another wire from the rear to the front when they install the camera. You need to tap into the LIGHT GREEN wire going to one of the backup bulbs.
The schematic showa it at 0.5, which translates to 20 gauge.
There is lots of room directly above the plastic panel above the passengers feet (the one with the light mounted on it). Pull out the two push pins along the front edge and it will fall down enough to do your work.
I don't think so, but there are DIY's posted for how to take apart the entire unit in order to replace the LED's.
Old Feb 22, 2010 | 05:39 AM
bowtiebubba
Thank you, i really appreciate your help.
To A few wiring questions
