Sponsored by: Innova
C6: quick wireing ? for you smart guys
Old Feb 22, 2010 | 12:28 PM
Tikiman12's Avatar
Tikiman12
Default C6: quick wireing ? for you smart guys
I'm planning a single 10 subwoofer install on my 05 vert with nav.
I've been reading through all the c6 Faq, and its been very helpful.
I've run into one simple problem that will be a quick answer for you guys.
I plan to just splice into the wires on the rear of the stereo (im not scared) and plug in the femail RCA wires to send the signal to my amp.
according to the picture at this link , http://www.lazyassgeek.com/c6-stereo...-unit-harness/ ,
Do i want to use the front's or the rears to send the best bass signal to my amp?
thank you . and let me know if you need me to clearify more
ALSO, are these wires the SAME colors for the same signal (+ or -) as they were on the c5 harness?
Old Feb 22, 2010 | 03:24 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
The signal is the same front & rear unless you've applied fader at the head unit so you can use whichever you like. Common practice is to use the rear channels and that's what I would do.
That's my site you posted the link to and the wire colors are listed there. I have no idea whether they're the same as C5 or not....
Old Feb 22, 2010 | 03:39 PM
Tikiman12's Avatar
Tikiman12
ok great thank you very much. exactly what i needed.
You have been a big help thank you. I've been through all your threads and the stickys and your site lol.
Old Feb 22, 2010 | 04:02 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
You're welcome, glad all that stuff was of use!
Old Feb 22, 2010 | 04:06 PM
Tikiman12's Avatar
Tikiman12
o one more. where is a good place to wire the "ON" wire. i forgot what its called, the wire that sends the on signal to the amp when the car is started and off signal when the car is off
Old Feb 22, 2010 | 05:19 PM
markcz's Avatar
markcz
You need to tap into the white wire at pin B3 of the big gray C1 plug for the TRIGGER
All of the C6 radio schematics and plug pin-outs are available here also.
To C6: quick wireing ? for you smart guys
