Sponsored by: Innova
Earphone Jacks In A Convertible?
Old Feb 27, 2010 | 11:15 AM
Cool Rod's Avatar
Cool Rod
Default Earphone Jacks In A Convertible?
OK, it seems that no matter what I do, I'm not going to hear my music in my convertible with the roof down when cruising at turnpike speed. Pretty much case closed.
On the other hand, I can hear my iPod just fine at any speed using in-the-ear earphones. No problem at all, no matter how fast I go.
Has anyone here installed earphone jacks using the factory Bose system? What part would I be looking for, and where would I find it?
If that's do-able, can I make the earphones silence the normal speakers when the earphones are plugged in?
In my mind's eye I'm thinking the earphone jacks would be installed on the console somewhere, probably by drilling through the black trim piece.
I'm just asking so I can tell my stereo shop to do it, but I want to know what I'm talking about before I go in looking dumb! :o
Old Feb 27, 2010 | 11:31 AM
Kale's Avatar
Kale
I haven't seen a kit, and I'm not sure how you would do it with the bose system. It's also probably illegal in your state.
Old Feb 27, 2010 | 11:51 AM
markcz's Avatar
markcz
It can be done, but I'm also sure it's illegal in most (if not all) states to drive with earphones on. Why not just listen to the ipod when you have the top down?
A nice upgrade to aftermarket speakers and an amp would solve your problems also
Old Feb 27, 2010 | 03:31 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
driving with earphones may keep you from hearing emergency sirens
Old Feb 27, 2010 | 05:33 PM
Cool Rod's Avatar
Cool Rod
Thanks for your help.
It sounds like I'll just have to settle for the iPod, like markcz said. I was hoping I'd be able to hear the programs on Sirius while I was driving along, especially on long trips.
The only realistic speakers that I've heard I could use are the JL Stealthboxes, and I think they're too expensive and of course I'd lose the use of the cubbies behind the seats. I figured earphone jacks would be a lot less expensive, and the sound quality would be excellent. The legal aspect is something I hadn't thought of.
Old Feb 27, 2010 | 08:37 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
How about speakers in the headrest(s) like the older Miata? Probably not cheap and SQ wouldn't be optimum but you wouldn't be breaking any laws.
And headphones are illegal in my state too.
Old Dec 19, 2012 | 12:31 PM
longhornvettte's Avatar
longhornvettte
2nd Gear
Default C-6 earphone jacks
An approach you can consider is to install a earphone jack with the interupter circuit at the rear speaker location on each side of the car. Then modify your earphones to have an independent plug to each side. It is usually bad to try to use a common ground (like is found on most earphones) for both the left and right channel (I think due to the fader circuitry) so you need independent plugs for each side. With this you disable the rear speakers when you plug in. use the console fader to take out the front speakers.
Old Dec 19, 2012 | 03:06 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you can tap in before the bose amp and wire some circuits up but it wont be plug and play
aftermarket speakers/amp will fix your problem
To Earphone Jacks In A Convertible?
