Sponsored by: Innova
Speaker problems
Old Mar 6, 2010 | 04:49 PM
artfahie's Avatar
artfahie
Default Speaker problems
I have a C5... I just has the seats redone & the door panels were removed as well. Everything is now as it should be EXCEPT the "stereo" no longer has a full sound... it's either the woofer / midrange , or a combination of the two that's missing from the sound. The highs are fine... the other stuff has absolutely disappeared in both speaker door panels. There is some distant "muffled" sounds of what would otherwise by a distinctive bass... the the midrange is totally absent... and (with the exception of some bass "ghosting"... I'm thinking that the bottom is otherwise absent as well.
As mentioned... both seats and side panels had been removed for thw work I had done but my upholstery installer has no idea what he must have done to have the situation occur...
ANY IDEAS !
Thanks...
Art Fahie
Maine
Old Mar 6, 2010 | 06:20 PM
Kale's Avatar
Kale
stock system? bose amps in doors unplugged
Old Mar 6, 2010 | 08:19 PM
markcz's Avatar
markcz
Sounds like your subs are not powering up. Check BOSE fuse #28 in the passenger footwell. If that isn't it, you can find the C5 radio schematics here.
Good luck
To Speaker problems
