Kenwood 9140
You cannot just replace your stock head unit with the Kenwood without getting several peripheral items to make everything work together, including steering wheel controls and such. Yes you will need an adapter plate for around the Kenwood to make it work with your center console, as you would with almost any HU swap.
See this thread:
http://forums.corvetteforum.com/audi...ll-a-head.html
This may get you started. It's not inexpensive to swap out so make sure it's worth it.
Yep just not a bolt in quick replacement!! But way worth it!!! The 9140 does a ton of stuff.I have one!Make sure when you get it to do the latest updates.www.kenwoodforums.com is a great place for any problems with it.
