This is for a C5 stealth box, I believe the airspace is .8 cubic ft. What 10" sub would you recommend and while your at it, what amp? FYI, I am looking for best bang for your buck. Thanks
why wouldn't you use a 12" sub instead of one 10" sub?
I did some research and it appears many of the 12" subs need more than .8 cubic ft of airspace. That is the only reason I am asking about 10" subs. If there is a 12" sub out there that would be at it's full potential with this set up, then I'm all for it.
a subthump stealth box has 0.85cf of air space and a 6 3/8" mounting depth. a kicker solo classic needs 0.88 cf of air space and 6 5/16" mounting depth.
the kicker solo classic is the perfect sub for a stealth box. i ran mine at 900w and it was awesome.
