Help on a new stereo
Could someone please tell me what kind (brand) of amps, speakers, box and anything else i may need to buy.
Oh...and i would like to spend around $2500. Is this possible??
all suggestions will be appreciated
Thanks,
Vince
Thanks,
Vince
My recommendation would be to stay with better quality equipment. Car audio pricing has dropped so much the last few years that you can pick up good gear pretty cheap.
Not to specifically recommend these brands, but you could put together a pretty good system for the price you're planning on spending:
Subwoofer enclosure for C6 - about $200 (Subthump box about $170 shipped, MadVette about $225 or $250 shipped when they have a sale going)
10" Subwoofer - about $130 (Rockford Fosgate P3 Shallow mount, or JL Audio 10W3v3 for $20 more - be careful about clearance in mounting depth and above the speaker with the targa top stored - some box/speaker combo's work better than others)
Mono subwoofer amp - about $175 (Rockford Fosgate Punch 300)
2 channel amp - about $140 (Rockford Fosgate Punch 200-2)
Front speakers - Component 6.5" set - $150 - $200 and up (JL Audio C2 series or JBL GT series are $150... the old Precision Power 356CS (a/d/s design) were great and were being closed out for around $150 recently).
Speaker plates for the 10" door opening - $100 from forum vendors
PAC adaptor - $100
Wiring / installation kits - $70 (Radio shack was clearing out the Monster Cable amp install kits recently for about $20, and the dash kit for the head unit from Metra or Scosche should be about $25, and you'll need good quality RCAs - about $30)
Pioneer AVIC 100BT - $1000
That leaves about $500 for the install. Since nothing needs to be built, the wiring/installation should fit in that amount I think (I do all my work myself, so I'm not sure what a good shop will charge).
All of the prices above are straight from a couple of reputable online shops, but they're not authorized dealers. If you want to buy from authorized dealers for those goods, it will be considerably more.
You might want to check out audio forums like DIYMA - they'll usually have a forum dedicated to hot deals online.
I agree with baxterboy - rear speakers aren't worth spending much money on. If you really want to upgrade them, just leave them running off the stock amplifier (non-Bose I hope?), and put some coaxials back there. But I'd recommend just leaving the stock ones hooked up, with the fader set forward, and the back speakers just used for fill.
PAC adaptor - $100
oh and there is really no use for rear speakers??... I was going to buy some good quality 2 way speakers like the Boston Acoustics SR55 but if its not worth it then maybe not
thanks,
Vince
thanks,
Vince
Some people like the Alpine PDX amps. They're small, and run really cool, so you can put them anywhere. They're not the most quiet of amps though, and they're moderately expensive, so some people don't like them. On the road, with the car running, the differences in sound between good amps is really small, so I wouldn't worry about the quality of the PDX personally, so if the size and flexibility is worth the money, it's not a bad choice.
Some people like the rear speakers, but personally, I don't like what it does to the imageing. The placement of the speakers, being really close to the back of your head, and pointing directly to the middle of the car, mucks with the imaging. So if the speakers are playing loud enough to really hear them, they sound weird. And if they're used just for fill, it doesn't matter too much how good of a speaker it is.
