Sponsored by: Innova
4 Gauge amp power wire through firewall?
Old Mar 17, 2010 | 03:06 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Default 4 Gauge amp power wire through firewall?
Is there room to put a 4 gauge amp power wire through an existing access grommet in the firewall to the battery, or will I need to drill a new hole?
I have a 2010 coupe.
Also, if it will go through an existing access hole, where would I find it? Is it behind the battery?
Thanks, Randy
Old Mar 17, 2010 | 04:49 PM
markcz's Avatar
markcz
Click here
2nd pic in post #3 shows what's behind the battery.
Factory cables run through in top left corner of the pic, you can remove the tape and push it through there, or drill a new hole as in the pic.
Old Mar 17, 2010 | 04:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
behind the battery and plenty or room
Old Mar 17, 2010 | 05:11 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
I simply went through the location for the stock wiring harness behind the battery, it is self sealing. I ran a 4-gauge power and a 4-gauge ground through it. So far the car hasn't exploded so I figure it's ok.
Old Mar 17, 2010 | 08:00 PM
ncvette_1FUNRIDE
Thanks everyone. I'll just use the hole that's already there since it seems there should be room for it there.
Old Mar 18, 2010 | 10:46 AM
parboy's Avatar
parboy
I fit a 1/0 gauge power wire thru the stock grommet, so you shouldn't have any problems.
Old Apr 19, 2010 | 09:00 PM
gp56's Avatar
gp56
When using the stock grommet is it easier from the inside to the battery or from the battery to the inside?
To 4 Gauge amp power wire through firewall?
