Sponsored by: Innova
DNX8120 Wiring Question
Old Mar 20, 2010 | 05:06 PM
slplank's Avatar
slplank
Default DNX8120 Wiring Question
I have a lot of wires up front as I have aftermarket speakers, sub, 2 amps, BU camera, iPod controls, NAV and Sat antennas etc. Although there is a lot of room around the area I'm thinking of thinning out some of the Kenwood wiring I'm not using. Is there any issue with me cutting off the Video 1, Video 2, Video Out leads on the Kenwood video harness? The only wire in that harness I need is the camera input wire. I realize if I ever want to sell or use elsewhere someone may need a new harness but I don't see that in the future and maybe I'll pick up a replacement harness to have just in case.
thanks
Old Mar 20, 2010 | 05:07 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
maybe just pop the pins and pull em out of the connector vs cutting
Old Mar 20, 2010 | 05:15 PM
slplank's Avatar
slplank
Surprisingly that is a very small connector so not sure I can pop the pins but a good idea and I'll give it a try first.
Old Mar 20, 2010 | 05:38 PM
slplank's Avatar
slplank
Once again you are the Master! Pins are popped and connectors are out.
To DNX8120 Wiring Question
