Sponsored by: Innova
Need Help MAKING MP3 CD
Old Mar 20, 2010 | 09:16 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Default Need Help MAKING MP3 CD
Need help making a CD with MP3's. Have used Media Monkey and I-Tunes both. 07 C-6 does not read disk. Need some help as XM sucks in a Vert. What is the trick??
Yes I have read the FAQ still not working.
Old Mar 21, 2010 | 01:20 AM
markcz's Avatar
markcz
From the owners manual:
If you burn your own MP3 disc on a personal
computer:
Make sure the MP3 files are recorded on a
CD-R disc.
• Do not mix standard audio and MP3 files on
one disc.
• Make sure playlists have a .mp3 or .wpl
extension, other file extensions may not work.
• Files can be recorded with a variety of fixed or
variable bit rates. Song title, artist name, and
album are available for display by the radio
when recorded using ID3 tags version 1 and 2.
• Create a folder structure that makes it easy to
find songs while driving. Organize songs by
albums using one folder for each album.
Each folder or album should contain 18 songs
or less.
Make sure to finalize the disc when burning
an MP3 disc, using multiple sessions. It is
usually better to burn the disc all at once.
• Do not use CD-RW discs.
• Do not use colored discs.
CD-R and finalized are the most common problems that I've read about.
Old Mar 22, 2010 | 01:42 PM
08 ATOMIC-Z
Thanks for the info. Have done all that already. Still does not work. :-(
To Need Help MAKING MP3 CD
