Sponsored by: Innova
C5 Double Din Install ??
Old Mar 27, 2010 | 08:24 AM
chargedc5's Avatar
chargedc5
Default C5 Double Din Install ??
I have some questions before install and will take any advice!
Any thing i need to know about the wiring or special wires to tap anything into?
Best place to put Xm box and then the wire
Best place to put navigation wire, I heard you can actually install it on top of the headunit?
How do I wire it so i can drive with video on and be able to change directions while driving!
Thank you for all responses!
Old Mar 27, 2010 | 09:52 AM
markcz's Avatar
markcz
The bezel needs to be modified/replaced. See C5 Audio FAQ thread or DoubleDmods.com
If keeping the stock speakers get something like this, if adding new amp/speakers get GMRAP to retain Retained Accessory Power, or if you don't care about R.A.P. just wire power from accessory pigtail in passenger floor.
Illumination, VSS wires are not present at radio harness. Reverse wire isn't inside dash anywhere. All are available, just not at the radio. See FAQ thread.
Lots of room above the passengers feet for boxes. Pull down flat plastic panel with light mounted on it.
Nav antenna isn't as picky as sat radio, just put it as high as possible if mounted inside dash. I had my sirius antenna sitting on top of the rear bumper (inside fascia) and it worked pretty good.
Bypass depends on unit being installed. AVIC411.com for pioneers, most kenwoods just need the parking brake wire grounded.
Old Mar 30, 2010 | 12:37 PM
wildwall's Avatar
wildwall
illumination is available on the hvac plug. nav and satellite antennas work just about anywhere in a plastic car.
To C5 Double Din Install ??
