Sponsored by: Innova
help.....
Old Mar 28, 2010 | 04:57 PM
chevyc6z51's Avatar
chevyc6z51
Default help.....
So guys I have my cd with factory nav, And I set up a sub new speakers( top of the line pioneers) Form like 2 years ago and to amps all good stuf not the best but good from what i am told. Ran everything the way you should from what you guys told me.. And it sounds great but It seems that my highs are killing my ears I have made adjustments on my nav but it still is a little much..Any tips help..Thanks for your time guys
Old Mar 28, 2010 | 07:12 PM
markcz's Avatar
markcz
Do your front speakers have an external crossover? Many have a switch on them that lets you change the tweeter loudness. My Polk db6501 has -3/0/+3, which I installed at 0, but will be changing to -3 when I install my soundproofing (one of these days).
Old Mar 28, 2010 | 08:13 PM
Paul 75 L82's Avatar
Paul 75 L82
Default It Works!
Old Mar 28, 2010 | 10:07 PM
chevyc6z51's Avatar
chevyc6z51
What is that??..I just have what came with the component speakers.And everything was set up with the stuff people on here said would be good. Do you think I should play with the amp? Or?? Thanks for you time.
Old Mar 28, 2010 | 10:23 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
I think I am explaining this right. Crossovers go between your amp and your component speakers. They control the separation of the highs and the mid-range.
Here is a photo of my Elemental Design components crossover.
Here is something I found online that explains it better:
A crossover is an electronic device that is used to send the appropriate signal to the correct speakers or drivers. A crossover sends only high frequencies to the tweeter, midrange frequencies to the midrange driver and so on.
Also:
The crossover slope describes how sharply or quickly the crossover attenuates (decreases) the amplitude (strength) of audio signals at frequencies above (low pass crossovers) or below (high pass crossovers) the crossover frequency. The slope is described in dB per octave. The higher the value, the sharper the roll-off, and the more control the listener will have over which frequencies are played by any particular speaker. A 24dB/octave slope is considered very steep (good) and a 6dB/octave slope is relative low (more difficult to control audio signals).
Old Mar 29, 2010 | 03:03 AM
chevyc6z51's Avatar
chevyc6z51
Also:
Thanks.. I know i have crossovers..But is this the problem. I mean every other note is fine the mids lows. Its just on some highs that alomost every song has its like to me ears and im a young guy. I know the guys that installed the set up tuned the amp but maybe I NEED TO RE-TUNE THE HIGHs on the amp?? Any help you guy can give or ideas would be great .thanks everyone
Old Mar 29, 2010 | 09:49 AM
simpleman68's Avatar
simpleman68
Feel free to shoot me a pm if you want to chat on the phone.
Often, you can get these type of problems figured out a lot quicker than throwing mud on the walls and folks trying to decipher what you have without knowing the whole picture.
Scott
Old Mar 29, 2010 | 10:42 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
attenuate the highs down on the crossover
Old Mar 29, 2010 | 09:58 PM
chevyc6z51's Avatar
chevyc6z51
Im soory what do u mean??.. Where is that at??
Old Mar 29, 2010 | 10:50 PM
markcz's Avatar
markcz
On the external crossovers, move the switch to the lowest number, probably -3.
Old Mar 30, 2010 | 03:07 AM
chevyc6z51's Avatar
chevyc6z51
O ok. Should I play with the amp b4 I do this???.I no that I would have to take off the door pans to get to external crossovers.
Old Mar 30, 2010 | 09:35 AM
simpleman68
pm on its way.
Scott
Old Mar 30, 2010 | 12:22 PM
wildwall's Avatar
wildwall
Check your treble setting on the head unit....you may be able to get a pleasing sound by turning it down...
Old Mar 30, 2010 | 09:49 PM
chevyc6z51's Avatar
chevyc6z51
Hey thanks for the info I have played with it a bit.. I have sounding great besides the highs .. Their killing me!!
Old Mar 30, 2010 | 10:20 PM
pentavolvo's Avatar
pentavolvo
did u look at ur tweeter attenuation yet
Old Mar 31, 2010 | 02:39 AM
chevyc6z51's Avatar
chevyc6z51
Im not going to lie that way over my head....
Old Mar 31, 2010 | 07:08 AM
pentavolvo's Avatar
pentavolvo
you need to look at the crossovers as markcz said odds are there is a switch or jumpers
To help.....
