Sponsored by: Innova
door speakers on a 89
Old Mar 13, 2002 | 08:47 PM
vettlesstintguy's Avatar
vettlesstintguy
Default door bose speakers on a 89
any pointers? i removed the grill just to look amd it looked like a bear to get out.
[Modified by vettlesstintguy, 6:48 PM 3/13/2002]
Old Mar 14, 2002 | 12:24 AM
Anguish's Avatar
Anguish
Default Re: door bose speakers on a 89 (vettlesstintguy)
Not hard to get out at all...
Pull the panel, the inner skin, and you're there :D
Old Mar 14, 2002 | 12:11 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I'm about to attempt the replacement of my door speakers this weekend. I talked to a guy with an 89 that had removed his door panels. His pointers were:
Remove all the screws
Remove the insert that contains the door handle, etc.
When you remove the panel place it on a stool or something so you don't break any of the wires.
The PITA on re-installation is replacing the part that manually locks the door.
I'm going to try to take pictures of my removal of the panels, bose speaker enclosures and installation of replacement speakers as I do it.
Old Mar 14, 2002 | 02:08 PM
Kale's Avatar
Kale
Default Re: door bose speakers on a 89 (jaa1988)
If you are removing the enclosures.. see the silver inner door panel? That's gotta come out. It has 3 rods, and 2 of them really suck to get to.
Old Mar 16, 2002 | 12:12 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Default Re: door bose speakers on a 89 (Kale)
Kale - Any tips on getting the rods out?
Edit - Nevermind, got it done. The top one was easy, it pops out with pressure between the silver panel and the rod. The second one was easy once I worked the panel out from the top and bottom it kinda popped out. When replacing it was a little difficult, but it all snapped together.
That silver piece has to come out, only way to get the enclosure out. Thought about reusing the enclosure, but it won't work without modification so its off to the lumber yard.
OBTW - How many pads are supposed to be holding the window at the top?
[Modified by jaa1988, 4:50 PM 3/16/2002]
To door speakers on a 89
