Sponsored by: Innova
Stereo install wiring question
Old Apr 9, 2010 | 08:34 AM
PR4424's Avatar
PR4424
Default Stereo install wiring question
Hello all,
I am about to install my first Nav system in four or five years in my C6 vert with Bose. I have several questions:
1. What is the best way to connect the wires on the harness to the GMCO? I previously crimped the wires but I always feel like there has to be a better way for a tighter connection (unless I am doing it wrong...I am self taught).
2. I am hooking up the Kenwood DNX9960 (top of the line NAV). Do I want to use the Bose amp or not? If so, how do I not use it...or use it? If I am using it do I just plug in the RCA's on the NAV to the RCA's on the HU?
3. Finally (for now), how difficult is it to actually get to the stereo. I've seen a write up on this forum and it didn't look too difficult....are there any tips or tricks I should know?
Thanks in advance for all your help!
Patrick
Old Apr 9, 2010 | 12:02 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Hey Patrick,
For question 1 I'd say strip & solder your head unit connections to the GMCO and if you have some heat shrink tubing to go around the soldered connections that's perfect, but some good ol' black tape will get it done too.,
Question 2 - if you are not replacing the amp as well then use the Bose amp, it has the crossovers, etc built in to feed the system properly. Check the FAQ stickied at the top of this section for my article on the best way to feed the signal.
Question 3 - Again check the FAQ, it isn't hard at all.
Old Apr 9, 2010 | 02:10 PM
PR4424's Avatar
PR4424
Thanks for the quick reply. I found the answers to 1 & 3 in the FAQ but I didn't see anything about how to set up the factory amp with the aftermarket stereo/GMCO....but maybe I am must missing it.
Could you point me in the right direction?
Thanks!
Old Apr 9, 2010 | 05:30 PM
markcz's Avatar
markcz
There isn't anything that can be 'set up' on the stock amp
Plug the GMCO into the car harness, connect the power wires, RCA plugs, and whatever other misc wires you need (VSS, dimmer...), then turn it on
Click here for a great DIY install thread. The only thing I can think of that isn't in it is to use the gray wire on the TC/AH button for the dimmer wire.
Using the stock amp setup isn't all bad. If you replace the 3.5" twiddlers in the doors it actually sounds pretty good. Polk db351 or Boston Acoustic S35 are popular replacements.
Old Apr 9, 2010 | 09:29 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
if using gmco get 2 sets of ground loop isolators the rca style
Old Apr 10, 2010 | 01:22 PM
PR4424's Avatar
PR4424
Thanks again for all the help. Ok, I just connected most of the wires. I plan on taking apart the C6 for the first time tomorrow. In the mean time, could somebody double check my wiring? I have a C6 Vert with Bose and no onstar and I'm using the GMCO and a Kenwood DNX9960 nav:
yellow GMCO to yellow HU
Black GMCO to Black HU & green parking brake cable (for the bypass)
Red GMCO to Red HU
Blue Power antenna GMCO to Blue/white PControl HU
RCA's on GMC to RCA's on HU with Ground Loop Isolator
The GMCO has wires that I am not sure about: orange (dash light illumination) and orange/white (dimmer). The HU wire is orange/white and says dimmer so do I just connect those or should I tie in the orange cable as well?
Finally, I am not using the HU's Blue Ant. Cont wire for anything. Do I need that connected to anything for better radio reception?
Thanks again for all the help!
Old Apr 10, 2010 | 01:47 PM
markcz's Avatar
markcz
The wires you detailed look correct.
Forget about the blue antenna wire from the HU, just tape the end so it doesn't short out.
The two orange wires on the gmco are useless for C6, just tape them also.
The other wires from the HU don't NEED to be connected, but can be in other areas of the car if you want to. The HU dimmer wire connects to the gray wire at the TC/AH button, check out this thread for details on the other wires.
Old Apr 14, 2010 | 02:37 PM
PR4424's Avatar
PR4424
Ok, so I finished most of the install...I just a have few things to take care of. One of the issues I am having is I only get certain radio stations that are extremely close. I am think that the amplified antenna is not powering on. How can I get that to power on?
Patrick
Old Apr 14, 2010 | 05:59 PM
markcz's Avatar
markcz
The antenna module is powered up by the same wire as the stock amp (blue/white from HU to blue on GMCO). If your speakers are playing, the antenna is powered, sorry
Old Apr 15, 2010 | 01:22 PM
PR4424's Avatar
PR4424
That's not what I wanted to hear!
Old Apr 18, 2010 | 04:11 AM
thesky's Avatar
thesky
5th Gear
Default Unclear about the antenna wire
I have a 2007 non-Bose which I installed a AVIC-X710BT. I used a C2R-GM24 (GMC0). I retained the OEM amps. I have the blue antenna enable wire from the HU connected to the blue wire marked "Antenna" on the GMCO. I now get an very loud POP from the speakers when the unit shuts down. Should I be connecting the remote amp enable wire from the HU to the Antenna wire instead if that is also the signal for the amp to power on? Would that make my POP go away?
Old Apr 18, 2010 | 09:21 AM
PR4424's Avatar
PR4424
I took my stereo apart again and found the antenna wire had gotten disconnected when I pushed the stereo back in. I pushed the antenna cable back in and everything works great now.
I do not have the power antenna cable connected from the HU at all. Just the blue/white pcontrol on the HU to the blue power antenna cable on the GMCO.
From what I have read on the forums, you need two RCA Ground Loop isolators in between your GMCO RCA's and your head units RCA's. That should get rid of the popping sound (from what I have read).
Good luck!
Old Apr 18, 2010 | 10:56 AM
markcz's Avatar
markcz
Good luck!
Glad you figured out the reception issues
The rest of your post is correct also
The blue/white wire from the HU is what needs to be connected to the blue wire on the gmco. If you use the blue wire from the HU your amp will only be powered when you're listening to the radio (not ipod/sat radio/CD/whatever).
The pop would probably go away if you installed two GLI's, but it may be caused by something else (most gmco installs don't get the pop).
Old Apr 18, 2010 | 12:57 PM
thesky's Avatar
thesky
5th Gear
I will try the Ground Loop Isolators. Changing the wire for the antenna/amp control from the antenna control out of the x710 to the system control out of the x710 still gives me the pop.
To Stereo install wiring question
