Sponsored by: Innova
need to know
Old Apr 9, 2010 | 03:10 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Default need to know
Does a 2000 corvette have the connectors, by the passengers footwell for a 12 disc cd player to connect to the harness
Old Apr 9, 2010 | 04:35 PM
Chuck A's Avatar
Chuck A
Or will a harness connect to the back of the stock radio?
Old Apr 9, 2010 | 05:21 PM
markcz's Avatar
markcz
It SHOULD have the footwell plugs, but the only way to know for sure is to look
Old Apr 9, 2010 | 05:26 PM
Chuck A's Avatar
Chuck A
Can you elaborate more
Old Apr 9, 2010 | 05:38 PM
markcz's Avatar
markcz
OK, I'll bite.
Pull up the cover in the passenger floorboard and look in the bottom right corner to see if the plugs are taped to the wire runs. One is probably running up the pillar with the door hinge on it, many have reported that one was tucked under the fuse box, some have found one under the door sill plastic piece. Some cars don't have them.
The only way someone can confidently answer the OP question is to look in your car
I almost hate to say it, but you can probably buy a used ipod and adapter for less cash than you can get a changer for. Have you considered that?
Old Apr 9, 2010 | 05:42 PM
Chuck A's Avatar
Chuck A
OK, I'll bite.
ok thanks, yea i started looking for it, the installer said i didnt have one, which was weird because i heard that all vettes have them, and i did see some kind of a connection, but had to head to work, wont be home until tommorow 4pm
Old Apr 10, 2010 | 06:31 PM
Chuck A's Avatar
Chuck A
Yes it does, 12 DISC CD player is in and works fine
To need to know
