Sponsored by: Innova
C$ headunit turns on then off?
Old Apr 15, 2010 | 10:27 PM
mellowout's Avatar
mellowout
Default C$ headunit turns on then off?
hey everyone, first off, i have a 93 6 speed coupe, the CDM was in the cubby hole, i do not have a passenger airbag. I wired everything up today, correctly to the best of my knowledge. I wired my headunit from the orange yellow and black wires from the CDM. orange to yellow, yellow to red, etc. I dont, however have the antenna connected.
Heres my problem, when i turn the key the headunit does not come on. i can hit eject on the headunit and it gets power and ejects the cd then turns right back off. the power button does not work but if i hit display it turns on then off. This is an aftermarket cd player by the way, im not sure what product number, but it has a cd player/aux slot.
anyone know what the problem may be? im contemplating running the yellow wire to the fuse box
Old Apr 16, 2010 | 10:14 AM
markcz's Avatar
markcz
Sounds like you have the battery constant and ground wires properly connected to the HU, but the switched power isn't there. I don't know anything about C4's, but the red wire from the HU definitely needs to have 12v supplied when the car is running.
