Sponsored by: Innova
Remote Start wire for Alarms
Old Apr 19, 2010 | 10:59 AM
Stealth_Inc's Avatar
Stealth_Inc
Default Remote Start wire for Alarms
Ok I had my Compustar alarm with remote start installed on my C5 a few months back. The guy installed the engine sensing wire on one of the injector wires. I found out about it about a week later and I honestly don't want to bother with going back there. Everything else works great, but well, my remote start doesn't work since I disconnected the wire. Where are you guys putting the engine started sensing wire?
Old Apr 20, 2010 | 11:03 AM
Jimmy 2 Times's Avatar
Jimmy 2 Times
should have gotten a remote start with a virtual tach
i haven't done a c5 in a while, but i believe the tach wire is the white wire. You can just find the wire on that is common on all 8
I will check the wiring later for you
Old Apr 21, 2010 | 02:58 PM
C5 Erick's Avatar
C5 Erick
I installed my compustar on my c5 and used an injector wire. There is no problem doing like this. Is your car a manual transmission or an auto? If its an auto you can program the remote start for tachless. If you have a manual then you will need to hook up the tach wire back up to the injector wire.
Old Apr 21, 2010 | 05:40 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
there really is nothing wrong with using an injector wire, hook it back up is the easiest thing to do
To Remote Start wire for Alarms
