Sponsored by: Innova
dnx7140 question?
Old May 5, 2010 | 01:14 AM
x-mann's Avatar
x-mann
Default dnx7140 question?
at night, the navigation display is way to bright. i turned down the contrast, brightness and color....did not change the nav display. is there a trick to this? and yes, it is set to auto and yes, it is on night mode because the background is black.
Old May 5, 2010 | 02:41 AM
SCS Red80's Avatar
SCS Red80
St. Jude Donor '10, '13
Two things you can check -
1. make sure your dimmer wire is hooked up correctly i.e there is a change in the display brightness when your lights are on, and off
2. there are brightness option available in both day and night settings of the headunit - meaning you can adjust the brightness, color, contrast when the lights are both on and off - assuming your dimmer is hooked up correctly.
Hope that makes sense, good luck.
Steve
Old May 6, 2010 | 07:18 PM
x-mann's Avatar
x-mann
Steve
i will check this out. thanks for the info
To dnx7140 question?
