Sponsored by: Innova
AVIC-Z110BT mute problems.
Old May 7, 2010 | 08:54 PM
FrameWise's Avatar
FrameWise
Default AVIC-Z110BT mute problems.
Question/problem:
After having a AVIC-Z110BT installed this winter I have been having problems with the head unit staying in mute for 15 min or so after I start the car. It is random and it just started. I do not push the mute button to cause this and when it is muted pushing the button does not do anything
Any thoughts?
Old May 7, 2010 | 11:21 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
odds are the actualy mute wire for your radio is shorting out against something, tape it up so its insulated
Old Aug 5, 2010 | 08:45 PM
EliteGreg's Avatar
EliteGreg
Same problem for me!!! I'm thinking it is heat related! (I'm in SC) and it only happens when I leave the car out in the sun for hours. Have you figured out a solution yet?
Old Aug 6, 2010 | 07:58 AM
FrameWise's Avatar
FrameWise
Not yet, but it 100% a heat problem, it never shuts down after the car is running. Only when getting in it after it has been in the sun for a few hours. My installer is going look at it again, I well kep you posted.
Old Aug 6, 2010 | 09:12 AM
EliteGreg's Avatar
EliteGreg
What interface are you using to pick up the mute wire? I'm using the GMOS-100i and am wondering if it is the component that is not working right. I might try cutting the mute wire and seeing what happens. One thing is for sure, if we are both having this problem, it's not a wiring issue.
Old Aug 6, 2010 | 09:49 AM
FrameWise's Avatar
FrameWise
Does yours ever ATT instead of MUTE?
Old Aug 6, 2010 | 09:57 AM
EliteGreg's Avatar
EliteGreg
That's a config option in the headunit. Under "Audio Settings", you can set mute to be "10db, 20db or all". 10/20db in an attenuation level and all means full mute (which will also pause a pausable music source). If it toggle this setting when it I'm having the problem, I can get different attenuation levels and full mute. I just can't disable it. Which is why I think the interface may be sending a faulty mute signal when it is hot.
To AVIC-Z110BT mute problems.
